Version 1.112
Get information about latest versions of software
sfgsdfg999
Re: Version 1.112
Post by sfgsdfg999 » Fri Jun 26, 2015 12:16 am
where is the file? under downloads there is only version 1.1. The only other file I see is 1.132 as experimental release in latest software versions.
Re: Version 1.112
Post by PSI-Motor » Fri Jun 26, 2015 12:20 am
Its upgraded to 1.132.
sfgsdfg999
Re: Version 1.112
Post by sfgsdfg999 » Sun Jul 05, 2015 3:28 am
used 1.134 for base map load, thats the only posted Tuner used 1.133 and now I get an error msg that I need 1.133 version on my laptop to access. Where do I get that 1.113 file? the reason is my andoid dash only shows RPM's, others - MAP, AFR, are all 0 value.
Re: Version 1.112
Post by PSI-Motor » Sun Jul 05, 2015 4:29 pm
sfgsdfg999
Re: Version 1.112
Post by sfgsdfg999 » Tue Jul 07, 2015 7:56 pm
I actually had 1.132, updated to latest 1.134 now all is good.
240sx2jz
Re: Version 1.112
Post by 240sx2jz » Tue Nov 10, 2015 2:15 am
i know this is probabley a newb question but where do i down load the software from? :?:
MrBmw
Re: Version 1.112
Post by MrBmw » Tue Nov 10, 2015 10:18 am
Racekid21
Re: Version 1.112
Post by Racekid21 » Thu Nov 26, 2015 1:51 pm
Hey,
if i download the new Version 1.155 , the program wont start. I had no problems with older versions.
Is there the possibility, that i can download an older Software Version?
Thanks !
roquete
Re: Version 1.112
Post by roquete » Thu Nov 26, 2015 1:59 pm
Did you try "run as administrator"?
Racekid21
Re: Version 1.112
Post by Racekid21 » Fri Nov 27, 2015 9:15 am
Hey, thanks for the quick response.
I tried that...but it didn't work.
I don't know what to do.
Greetings
ATS_Scott
Re: Version 1.112
Post by ATS_Scott » Fri Nov 27, 2015 7:14 pm
i just downloaded and installed 1.155, and it runs just fine for me. do you get a specific error when you click on the shortcut?
nolagg
Re: Version 1.112
Post by nolagg » Sat Jan 16, 2016 5:38 pm
Just got my ecu and base map for 2jzgte single turbo with stock 440's. When I downloaded the software, it came up as version 1.100 .should I be ok?? Would like to know before I upload the base map and drive the car home 20 miles.
Georgeen
Version 1 112
Post by Georgeen » Sat Mar 05, 2016 1:04 pm
version 3 is much better. thanks for upgrading.
I told you I would help you with it ... lol
ThomasCliex
Self-perceived effects of Web pornography use, genital appearance fulfillment, as well as sex-related self-confidence am
Post by ThomasCliex » Sat May 12, 2018 6:37 am
Abstract
This study analyzed the associations amongst the regularity of checking out Net porn, ideas regarding exactly how realistically pornography depicts sex, self-perceived impacts of one's pornography usage, genital look satisfaction, and also sexual self-worth in young adults. Online data were accumulated from four ease examples of college student from Norway as well as Sweden, members of a queer young people company, as well as readers of a sexual publication. Due to cultural resemblances and the similar size and patterns of the bivariate correlations amongst the examples on the study variables, they were pooled right into a solitary sample (N = 1,274). Most of males (81.1%) and a minority of ladies (18.1%) reported at least weekly use Net porn on their desktop computers, whereas utilizing a cellphone or tablet computer was much less typical. A lot of the participants had sought mainstream pornographic web content. Those with a stronger belief in x-rated realism were more likely to view the impact of pornography usage positively. A hypothesized partnership in between self-perceived favorable effects of porn usage and also a greater degree of sexual self-worth was located for males yet not for females. This result was partially due to greater contentment with genital appearance among the men that generally viewed mainstream porn. Genital appearance complete satisfaction was linked to higher sex-related self-worth for females, but it was not connected to the self-perceived effect of porn use. The results show that porn might increase personal sexual scripts for both men and women, and might have a positive, although moderate, influence on the sexual self-confidence of young male adults.
Key phrases: Net pornography; genital look; sexual self-confidence
Introduction
During the past 20 years, there appears to have been a mainstreaming of pornography in the mass culture, as an example, in video and females's literary works (Comella, 2013). Continual advancements in innovation have made Net pornography significantly extra easily accessible to young adults worldwide. In the past decade, Swedish and also Norwegian researchers have actually wrapped up that the majority of young people have been subjected to porn and record favorable effects of utilizing it (Daneback, Cooper, & Månsson, 2005; Knudsen, Løfgren-Mårtenson, & Månsson, 2007; Træen, Nilsen, & Stigum, 2006; Træen, Spitznogle, & Beverfjord, 2004). Nonetheless, study on the influence of Web porn use continues to lack numerous areas. Štulhofer et al. (2007) suggested that a new research program ought to have a higher concentrate on individuals' wellness and also stay clear of ideological framework as much as feasible. On top of that, the role of the genre (sort of pornographic material) must be included in the layout of research on pornography. This referral involves a change from the standard focus on the connection between watching porn and also sexual risk habits to the capacity for favorable results of making use of mainstream and non-mainstream porn. Wright, Bae, as well as Funk (2013) additionally recommended that future study on pornography broaden its scope to include ladies generally, and also much more especially, to consist of individuals' perceptions of pornography's realistic look as well as the duty of pornography in sexual knowing.
http://www.ah-moore.com/__media__/js/ne ... ornzam.com
http://www.kiriko.com/__media__/js/nets ... ornzam.com
http://www.econolodge.net/__media__/js/ ... ornzam.com
http://infinity-foods.com/__media__/js/ ... ornzam.com
http://www.tipcoeurope.com/__media__/js ... ornzam.com
http://www.tcbox.com/__media__/js/netso ... ornzam.com
http://www.technologyonthe.net/__media_ ... ornzam.com
http://www.aimdme.com/__media__/js/nets ... ornzam.com
http://www.hubber.com/__media__/js/nets ... ornzam.com
http://abeautifulplace.com/__media__/js ... ornzam.com
https://search.auone.jp/?q=www.pornzam.com
http://registereverywhere.cc/__media__/ ... ornzam.com
http://ihatecarmaxscion.net/__media__/j ... ornzam.com
http://www.autoguide.net/cgi-sec/url_ex ... ornzam.com
http://www.getemgone.com/__media__/js/n ... ornzam.com
http://redjane.com/__media__/js/netsolt ... ornzam.com
http://exxxlusive.com/cgi-bin/crtr/out. ... house.html
http://deancharlesassoc.com/__media__/j ... ornzam.com
http://in2shakespeare.net/__media__/js/ ... ornzam.com
http://donzuckerman.com/__media__/js/ne ... ornzam.com
http://www.paradeofhomesdenver.net/__me ... ornzam.com
http://www.nestoit.com/__media__/js/net ... ornzam.com
http://kookydough.com/__media__/js/nets ... ornzam.com
http://2chbbs.net/url.cgi?http://www.pornzam.com
http://www.cp77.far.ru/click.phtml?url= ... ornzam.com
http://www.redplumcoupons.com/__media__ ... ornzam.com
http://www.expandurl.net/expand?url=htt ... arch/fresh
http://www.43fifth.com/__media__/js/net ... ornzam.com
http://vintagetwat.com/dtr/link.php?id= ... ornzam.com
http://doctorsdialogue.com/__media__/js ... ornzam.com
http://clwholdings.com/__media__/js/net ... ornzam.com
http://snorefreezer.com/comment/html/in ... 1&id=40683
http://www.e1start.ru/2008/ViewURL.php? ... ornzam.com
https://www.ackermantoyota.com/redirect ... t-100.html
http://www.sptny.com/blog/?p=2629
http://www.convertit.com/Redirect.ASP?T ... ornzam.com
http://www.joesmithauto.com/__media__/j ... ornzam.com
http://www.savagecomics.com/crtr/cgi/ou ... ornzam.com
http://www.tango-hayakawa.net/modules/w ... ornzam.com
http://unifiedindustries.com/__media__/ ... ornzam.com
http://psygod.ru/redirect?url=http://www.pornzam.com
http://www.porrfilmtillalla.com/ept/out ... ent-search
http://www.steammovies.net/__media__/js ... ornzam.com
http://www.easthope.de/__media__/js/net ... ornzam.com
http://merle-norman-day-spa.org/__media ... ornzam.com
http://www.bedandbreakfasts.net/spitfir ... ornzam.com
http://holiday-anglers.zenno.info/modul ... ornzam.com
http://www.magnificentminds.com/__media ... ornzam.com
http://wongwinnie.com/__media__/js/nets ... ornzam.com
http://www.bigtruckdepot.com/__media__/ ... ornzam.com
ThomasCliex
Self-perceived results of Net porn usage, genital appearance contentment, as well as sex-related self-esteem among young
Post by ThomasCliex » Sat May 12, 2018 6:38 am
Abstract
This research examined the associations among the regularity of checking out Net pornography, beliefs about how reasonably pornography represents sex, self-perceived impacts of one's porn use, genital look contentment, and sex-related self-worth in young adults. On the internet data were gathered from four comfort samples of university students from Norway as well as Sweden, members of a queer young people organization, and also viewers of an erotic magazine. Because of social similarities as well as the equivalent magnitude and patterns of the bivariate connections amongst the samples on the research variables, they were merged right into a solitary example (N = 1,274). Most of men (81.1%) as well as a minority of females (18.1%) reported at the very least weekly use Web pornography on their personal computers, whereas utilizing a smart phone or tablet computer was much less typical. The majority of the individuals had looked for mainstream adult content. Those with a more powerful idea in pornographic realism were most likely to perceive the result of pornography use favorably. A hypothesized partnership in between self-perceived favorable impacts of pornography usage and a greater level of sexual self-esteem was located for males yet except ladies. This result was partially because of higher fulfillment with genital appearance among the men that generally viewed mainstream porn. Genital look fulfillment was linked to greater sexual self-confidence for ladies, however it was not related to the self-perceived result of porn use. The outcomes show that porn may expand personal sex-related manuscripts for both men and women, and may have a favorable, although modest, impact on the sexual self-confidence of young male adults.
Key phrases: Web porn; genital appearance; sexual self-worth
Intro
Throughout the previous two decades, there appears to have been a mainstreaming of pornography in the mass culture, for instance, in music videos and women's literature (Comella, 2013). Continual developments in technology have actually made Net porn increasingly extra available to young adults worldwide. In the past decade, Swedish as well as Norwegian scientists have ended that the majority of young adults have been subjected to pornography as well as record favorable impacts of using it (Daneback, Cooper, & Månsson, 2005; Knudsen, Løfgren-Mårtenson, & Månsson, 2007; Træen, Nilsen, & Stigum, 2006; Træen, Spitznogle, & Beverfjord, 2004). However, research study on the influence of Internet pornography usage continuouslies lack a number of areas. Štulhofer et al. (2007) suggested that a brand-new research schedule must have a greater focus on individuals' wellness and prevent ideological framing as much as feasible. Furthermore, the duty of the genre (type of x-rated material) need to be included in the style of research study on porn. This suggestion includes a shift from the traditional concentrate on the connection in between viewing porn and also sexual danger behavior to the potential for favorable end results of using mainstream and non-mainstream pornography. Wright, Bae, and also Funk (2013) likewise suggested that future research study on pornography broaden its scope to consist of ladies in general, and also extra especially, to include individuals' perceptions of porn's realistic look as well as the role of porn in sexual understanding.
http://www.motorcityguitars.com/__media ... ornzam.com
http://medspacancun.net/__media__/js/ne ... ornzam.com
http://indiariskmanagement.com/__media_ ... ornzam.com
http://hooded.net/pagetools.asp?emb=1&d ... 005-search
http://broadbandcspan.com/__media__/js/ ... ornzam.com
http://rpspayroll.com/__media__/js/nets ... ornzam.com
http://www.discount-associates.com/porn animes-search
http://gallio.net/__media__/js/netsoltr ... ornzam.com
http://www.boosterblog.net/vote-146-144 ... ch&popup=1
http://18teenmodel.com/cgi-bin/crtr/out ... ornzam.com
http://kaniv.info/redirect/?url=Http://www.pornzam.com
http://www.womenheart.org/link.asp?e=@@ ... ornzam.com
http://www.lumenstock.com/__media__/js/ ... ornzam.com
http://www.joelosteen.net/__media__/js/ ... ornzam.com
http://mobile.altmaster.ru/golink.php?l ... ornzam.com
http://www.members-los.org/__media__/js ... ornzam.com
http://www.multimedia-designer.com/__me ... ornzam.com
http://www.google.sm/url?q=http://www.pornzam.com
http://www.hotterthanfire.com/cgi-bin/u ... ornzam.com
http://www.zooclub.biz/gotoexternal?u=www.pornzam.com
https://www.argentcu.org/redirect.php?u ... ornzam.com
http://www.cboestockexchange.org/__medi ... ornzam.com
http://www.ste.ag/go.php?http://www.pornzam.com
http://goxxxtube.com/cgi-bin/a2/out.cgi ... ornzam.com
http://wildwoodonfire.com/__media__/js/ ... ornzam.com
http://www.strikeforcelawgroup.com/__me ... ornzam.com
http://www.bestaviationsites.com/cgi-bi ... ornzam.com
http://drchriswood.com/__media__/js/net ... ornzam.com
http://nutritionbasics.com/__media__/js ... ornzam.com
http://www.bpcitigroupcenter.com/__medi ... ornzam.com
http://www.classicvintagetube.com/cgi-b ... ornzam.com
http://rebel-alliance.com/__media__/js/ ... ornzam.com
http://www.stormvloedkering.info/__medi ... ornzam.com
http://wrapdaddys.com/__media__/js/nets ... ornzam.com
http://www.google.com.gi/url?q=http://www.pornzam.com
http://joven.net/__media__/js/netsoltra ... ornzam.com
http://honsagashi.net/mt-keitai/mt4i.cg ... nal-search
http://www.santanderbanefe.com/__media_ ... ornzam.com
http://yourloveisprecious.com/__media__ ... ornzam.com
http://www.youwillbefamous.com/__media_ ... ornzam.com
http://killerbug.com/__media__/js/netso ... ornzam.com
http://e-premiumfinancing.net/__media__ ... ornzam.com
http://dentalxrays.org/__media__/js/net ... ornzam.com
http://www.pinksandshotel.com/__media__ ... ornzam.com
http://recycleasiaalliance.net/__media_ ... ornzam.com
http://imsd.com.ua/bitrix/rk.php?goto=h ... -it-search
http://ufoma.com/__media__/js/netsoltra ... ornzam.com
http://bethshalombz.org/gallery/main.ph ... ornzam.com
http://patient.net/__media__/js/netsolt ... ornzam.com
http://intermarineusa.info/__media__/js ... ornzam.com
ThomasCliex
Self-perceived effects of Internet porn use, genital appearance contentment, and sexual self-worth among young Scandinav
Post by ThomasCliex » Sat May 12, 2018 6:42 am
Abstract
This study analyzed the associations among the frequency of watching Net pornography, beliefs about exactly how realistically pornography portrays sex, self-perceived effects of one's porn usage, genital look contentment, and also sexual self-worth in young people. On the internet information were collected from 4 benefit samples of university students from Norway as well as Sweden, participants of a queer youth company, as well as visitors of a sexual publication. Due to cultural similarities and the similar size as well as patterns of the bivariate relationships among the examples on the research study variables, they were merged right into a solitary sample (N = 1,274). The majority of males (81.1%) as well as a minority of ladies (18.1%) reported a minimum of weekly use of Internet pornography on their desktop computers, whereas making use of a mobile phone or tablet computer was less usual. Most of the individuals had actually looked for mainstream pornographic material. Those with a more powerful belief in pornographic realistic look were more likely to regard the impact of pornography use positively. An assumed partnership between self-perceived favorable effects of pornography usage and a greater degree of sex-related self-esteem was located for men but except ladies. This outcome was partially because of greater contentment with genital look among the men who mostly saw conventional pornography. Genital appearance fulfillment was connected to higher sex-related self-worth for ladies, but it was not connected to the self-perceived effect of pornography usage. The results suggest that pornography may broaden individual sex-related manuscripts for both men and women, and also could have a favorable, although moderate, impact on the sexual self-confidence of young male grownups.
Keywords: Net pornography; genital appearance; sex-related self-esteem
Introduction
During the past 20 years, there appears to have actually been a mainstreaming of porn in the mass society, as an example, in music videos and ladies's literature (Comella, 2013). Continual developments in technology have made Web porn increasingly more obtainable to young people worldwide. In the previous decade, Swedish and also Norwegian researchers have ended that most of young adults have actually been exposed to porn as well as record positive effects of utilizing it (Daneback, Cooper, & Månsson, 2005; Knudsen, Løfgren-Mårtenson, & Månsson, 2007; Træen, Nilsen, & Stigum, 2006; Træen, Spitznogle, & Beverfjord, 2004). However, research on the effect of Net pornography use remains to lack several locations. Štulhofer et al. (2007) suggested that a new study program ought to have a better focus on people' wellness and prevent ideological framing as high as feasible. Furthermore, the function of the category (sort of pornographic material) need to be consisted of in the layout of study on porn. This referral includes a change from the typical concentrate on the relationship in between seeing porn and sexual threat actions to the capacity for favorable results of using mainstream and non-mainstream porn. Wright, Bae, and Funk (2013) also recommended that future research study on porn expand its range to consist of women as a whole, and also much more especially, to consist of individuals' perceptions of pornography's realistic look as well as the function of pornography in sex-related learning.
http://www.largopubliclibrary.net/__med ... ornzam.com
http://aegworldwide.de/__media__/js/net ... ornzam.com
http://gummifuger.dk/2nd-london-location/
http://www.sanjosesur.net/__media__/js/ ... ornzam.com
http://www.faadvisory.my/client-login-0 ... ornzam.com
http://www.superstrength.com/__media__/ ... ornzam.com
http://wifi.pokemon-dp.net/battle/link. ... icial-dash
http://historiccharlestoncollection.com ... ornzam.com
http://luggage.nu/store/scripts/adredir ... ornzam.com
http://www.microplus.it/?p=5051
http://www.onlyrockandroll.com/__media_ ... ornzam.com
http://www.5course.com/__media__/js/net ... ornzam.com
http://smartbiopharm.com/__media__/js/n ... ornzam.com
http://watsonpainting.com/__media__/js/ ... ornzam.com
http://www.mysalestax.net/__media__/js/ ... ornzam.com
http://www.h20proofapparel.net/__media_ ... ornzam.com
http://www.gamer.ru/runaway?href=http://www.pornzam.com
http://ridepatco.com/__media__/js/netso ... ornzam.com
http://eglobalcustody.net/__media__/js/ ... sun-search
http://www.peterpanbusmarketing.com/com ... 68163.html
http://www.listie.com/__media__/js/nets ... ornzam.com
http://workstrategy.info/__media__/js/n ... ornzam.com
http://racing-form.com/__media__/js/net ... ornzam.com
https://www.pervbank.ru/redir.php?url=h ... -24-search
http://www.slavery.com/__media__/js/net ... ornzam.com
http://nakedtrees.com/__media__/js/nets ... ornzam.com
http://corepoweryoga.net/__media__/js/n ... am.com&amp
http://nydepartmentofhealth.net/__media ... =1&button=??
http://www.les-small.net/__media__/js/n ... ornzam.com
http://quitonce.org/__media__/js/netsol ... ornzam.com
http://www.girlsurfshops.com/__media__/ ... 2791-video
https://reviblo.com/cv/link.php?mid=739 ... ornzam.com
http://keysextube.com/cgi-bin/crtr/out. ... ornzam.com
http://deanisidrophotography.com/__medi ... ornzam.com
http://russianpulse.ru/goto?url=http:// ... arch/fresh
http://www.robertsonfamily.net/__media_ ... ornzam.com
http://wetpussymature.com/q/go.php?url= ... ornzam.com
http://dpsons.com/__media__/js/netsoltr ... ornzam.com
http://www.pafxpickups.com/__media__/js ... ornzam.com
http://www.dailyjobs.com/__media__/js/n ... ornzam.com
http://commonapp.com/__media__/js/netso ... .com/somac
http://www.nylonx.net/cgi-bin/at3/out.c ... ornzam.com
http://www.google.cz/url?q=http://www.p ... -jauh.html
http://iusports.com/__media__/js/netsol ... ornzam.com
http://dashlove.biz/__media__/js/netsol ... ornzam.com
http://maps.google.com.sa/url?q=http://www.pornzam.com
http://fruitdeliverylosangeles.com/__me ... ornzam.com
http://www.productsforabetterlife.net/_ ... ornzam.com
http://beatrigger.com/__media__/js/nets ... ornzam.com
http://www.attorneypractice.com/__media ... ornzam.com
Post Reply
stół kuchenny okrągły
Who is online
Users browsing this forum: No registered users and 0 guests
