Analog inputs
All information about power management unit
Post Reply
turbofreak
Analog inputs
Post by turbofreak » Mon Dec 04, 2017 7:17 am
Do the analog inputs only handle 5 volts max? Can it take a 12 volt signal?
jgm
Re: Analog inputs
Post by jgm » Mon Dec 04, 2017 12:54 pm
Yes, it can take 12 volt signal, but can only measure 0..5V.
It's okay if you want to use it as the switch (Active high switch).
You may notice subtle changes in voltage on unconnected analog inputs. If this is a problem for you, you can always connect 12V through a resistor.
Post Reply
stół kuchenny okrągły
Who is online
