Latest software 0.42.5 (experimental)
Post Reply
jgm
Re: Latest software 0.24.0 (experimental)
Post by jgm » Mon Apr 10, 2017 5:28 pm
0.024.0, 2017-04-10
New Features:
- Support for Life Racing keyboard.
- Support for new Ecumaster 3x2 (7 colors) keyboard.
- Speed of CAN2 could be configured.
Improvments:
- Confirmation message added when deleting element that is referenced by other element.
- "EMULATED" text is shown on toolbar of Output/Analog Monitor when apropriate Emulator is used.
- Import .CANX file: CANbus ID could be configured.
- Pinout Generator - added CANbus Mobs and Keyboards.
- EMU_BLACK.canx updated: added inputs c_ecu_nitrus and c_ecu_starterRequest
See changelog for more details.
If you have any problems with this release please post below or contact us directly.
jgm
Re: Latest software 0.25.0 (experimental)
Post by jgm » Mon Apr 24, 2017 6:01 pm
0.025.0, 2017-04-24
Improvments:
- CANbus Input: Timeout value and Default value separated.
Fixes:
- Fixed Ecumaster USBtoCAN rare disconnection bug. USBtoCAN software update is offered automaticly when starting PMU Client.
- Fixed CANbus Export – channels were accidentally changed when deleting other elements.
jgm
Re: Latest software 0.26.0 (experimental)
Post by jgm » Tue May 09, 2017 4:23 pm
0.026.0, 2017-05-09
There is new PMU software package available to download.
New Features:
- CAN 2.0B support with extended ID (29 bits)
Improvments:
- Improved reliability of client on slow computers
Fixes:
- Fixed crash when saving some projects
- Fixed loading of projects containing channel with dot character (e.g. c_pmu.a3.voltage)
jgm
Re: Latest software 0.26.2 (experimental)
Post by jgm » Mon Jun 19, 2017 11:10 am
0.026.2, 2017-06-19
Fixes:
- (firmware) Fixed not responding buttons on Ecumaster keyboard
Improvments:
- Ecumaster USBtoCAN - performance improved on slower computers
jgm
Re: Latest software 0.26.5 (experimental)
Post by jgm » Tue Jul 04, 2017 5:34 pm
0.026.5, 2017-07-04
This is Client only update. Contains firmware 0.026.2, the most recent compatible firmware.
Fixes:
- Fixed Group Selection command (Ctrl+G or button "Group"). The names of all elements in the project were corrupted after this command.
jgm
Re: Latest software 0.26.6 (experimental)
Post by jgm » Mon Aug 07, 2017 9:55 am
0.026.6, 2017-08-07
Fixes:
- (firmware) Fixed proper activation of brake circuit for wipers. Wipers should park as expected.
- (client) Two crash bugs have been fixed.
jgm
Re: Latest software 0.31.0 (experimental)
Post by jgm » Wed Oct 04, 2017 5:13 pm
0.031.0, 2017-10-04
New features:
- Improved Power Control Model. Support for devices with delayed activation (such a ABS module). See technote: "Improved Power Control Model for PMU16 https://www.ecumaster.com/files/PMU/Imp ... 6_rev1.pdf
- Password protection
- Added question: “Use client data” or “Get data from PMU” if projects are different when connecting
- Decimal places in CANbus Input, multipliers in CANbus Export and Number
- Reconnect command for USBtoCAN – two PMU can be turned on one after another
Improvements:
- Hot unplug/plug-in Ecumaster USBtoCAN possible
- Several GraphLog improvements including bitfields, Autoscale and Display filter
- Logs saved on PC: It's now possible to analyze logs, even if some modification was made to the project. Only names of elements must match.
- Pausing the GraphLog works as expected in all situations
jgm
Re: Latest software 0.31.1 (experimental)
Post by jgm » Fri Oct 13, 2017 2:59 pm
0.031.1, 2017-10-13
This is Client only update. Contains firmware 0.031.0, the most recent firmware.
Fixes:
- Fixed connection problems between Ecumaster USBtoCAN and the latest firmware 0.031.0
jgm
Re: Latest software 0.33.0 (experimental)
Post by jgm » Mon Nov 20, 2017 7:34 pm
0.033.0, 2017-11-20
This version solves several crash bugs in Client. It's recommended, especially when you are working with multiple PMUs.
New features:
- PWM tables (firmware)
Improvements:
- Wipers: “Brake delay time” added (firmware)
Fixes:
- Several crash bugs have been fixed in Client.
jgm
Re: Latest software 0.34.0 (experimental)
Post by jgm » Thu Dec 07, 2017 7:45 pm
0.034.0, 2017-12-07
This firmware fixes CAN terminator issues on CAN1 / CAN2.
Now it works as documented:
CAN1: no terminator (USBtoCAN termination or external terminator on CAN1 required)
CAN2: user selectable terminator (Treeview/PMU/CANbus setup)
Improvements:
- Switch element – range has been extended to 0..255 (up from 0..4)
- Default frequency of some channels has been increased:
** pmu.o?.voltage now logged at 25Hz (up from 5Hz)
** pmu.a?.voltage now logged at 25Hz (up from 5Hz)
** pmu.acc*/pmu.gyro* now logged at 25Hz (up from 5Hz)
Fixes:
- Fixed terminator issues on CAN1 / CAN2
jgm
Re: Latest software 0.34.1 (experimental)
Post by jgm » Thu Dec 14, 2017 6:13 pm
0.034.1, 2017-12-14
Fixes:
- Fixed bug with minimum and maximum value when creating the Table.
- Password is now correctly replaced with ●●●●●● (fixed regression from version 0.033)
jgm
Re: Latest software 0.35.0 (experimental)
Post by jgm » Thu Dec 21, 2017 7:50 pm
0.035.0, 2017-12-21
New features:
- Support for new '4x2 Ecumaster (7 colors)' keypad
- Support for Pectel SQ6 CAN stream (Use Import CANX from Project Tree)
jgm
Re: Latest software 0.35.1 (experimental)
Post by jgm » Tue Jan 02, 2018 5:21 pm
0.035.1, 2018-01-02
Fixes:
- (client) Fixed crash when editing CANbus Mob on firmware lower than 0.035
jgm
Re: Latest software 0.35.2 (experimental)
Post by jgm » Mon Jan 08, 2018 11:16 am
0.035.2, 2018-01-08
Fixes:
- (client) Fixed crash when creating/editing Switch (bug since client version 0.034.1)
jgm
Re: Latest software 0.42.1 (experimental)
Post by jgm » Fri Mar 16, 2018 4:46 pm
0.042.1, 2018-02-28
New features:
- Support for new '6x2 Ecumaster (7 colors)' keypad
- Changing back light color for 7-colors Ecumaster keyboards
- Delays in IsTrue/isFalse/comparision operations. Examples:
a) channel is 1, when c_ecu_rpm > 2000 for 5s
b) channel is 1, when c_csb_switch1 is holded down for 1s
- Pulse operation - retrigger (retriggering pulse in the middle of active pulse)
New CAN Streams:
- Motec M1 ECU
- ViPec/Link ECU
jgm
Re: Latest software 0.42.5 (experimental)
Post by jgm » Mon Apr 09, 2018 4:43 pm
0.042.5, 2018-04-09
Fixes:
- Function evaluation when “True delay” and “False delay” parameters were both non-zero fixed.
- Output voltage is now properly measured on PMU HW3 model.
Post Reply
stół kuchenny okrągły
Who is online
