Using factory knock sensors and autometer ones
Support for EMU BLACK device
Post Reply
LopinRD
Post by LopinRD » Sat Jun 09, 2018 1:03 am
After seeing that the sold knock sensor is a bosch one, are they the same ones you can find in SR20s? They look exactly the same but i dont know if theres something else, i have a ton of those i could use.
Also is it possible to use those autometer sending units with the emu black? Oil temp, Water temp, i have all of those from autometer.
Aaaand which bluetooth adapter should i get for the black? the Can bus one or the normal one?
samvel
Re: Using factory knock sensors and autometer ones
Post by samvel » Fri Jun 15, 2018 11:56 am
Post a picture or partnr of Sr20 oem knk sensor. If i remember i`ve used it and should be fine.
Again, we need more info about sensors. Probably they`re single wire type without separated gnd. Possible to use, but i`d use better ones for ecu.
You need CAN-BT.
Post Reply
stół kuchenny okrągły
Who is online
