Trouble Building a Switchable Map
Support for EMU BLACK device
Post Reply
WCCoffey
Post by WCCoffey » Tue Jun 13, 2017 3:35 am
I have 2 different maps and I want to build a single switchable map.
My problem is I cannot load or copy the cells from one map into the other.
For example, if I highlight the cells in Map #2 and then copy them. When I go to paste them into ignition map #2, when I right click I cannot paste the cells.
Secondly, I've tried saving the ignition table, then when I go to open it in the other map absolutely nothing happens.
I really don't want to have to go in and type each seperate cell in at a time. I'm sure I'll mess it up and will take me hours with all the trims.
pric
Re: Trouble Building a Switchable Map
Post by pric » Tue Jun 13, 2017 12:51 pm
So you have two different emu project files and you want to use the table set of one project as second table set for the other project?
>>In the second project copy the values from the first table set to the second table set.
Store the second tables from the second Project and import the tables as second tables into your first project.
So #2 is imported in #2.
Mercedes C280 M104 Turbo
WCCoffey
Post by WCCoffey » Wed Jun 14, 2017 1:49 am
Ah, that worked great. Thanks!
Post Reply
stół kuchenny okrągły
Who is online
