Triggering CAN-EGT logging ??
Post Reply
imakehp
Post by imakehp » Thu Dec 20, 2018 7:45 am
Since there doesn't seem to be a way to get ECUMaster EGT to CAN to connect with my Megasquirt2 unit is there a way I can get the EGT/CAN software/program to start logging automatically or if a certain parameter is met?
I can "start logging" while in the program but need it to start logging at the start of a run in the race car...any ideas?
imakehp
Re: Triggering CAN-EGT logging ??
Post by imakehp » Wed Dec 26, 2018 11:38 am
I have the EGT to CAN plugged into a computer under my dash using a USB cable. It connects and work perfectly through the USB cable. I can get it to start logging by hitting SHIFT+F9 ....obliviously it stops logging when I hit SHIFT+F9 again....
Does ANYBODY have an idea how I can do this myself inside the racecar right before I stage? I don't have a keyboard or monitor in the car when I'm racing so it would have to be on a button OR if the program could be made to start logging after the EGT temps get up to 1000* F for instance?
I tried using the RaceCapture software but I guess it won't run because I'm only using the EGT to CAN module....
ANY IDEAS ?? PLEASE
Post by Karel » Wed Jan 30, 2019 10:35 pm
Yes you can setup parametric logging. So you can define conditions for logging start and stop. For example temp, speed or any other conditions.
Post Reply
stół kuchenny okrągły
Who is online
