MIATA WRONG RPM READ DET3 +VIDEO
DET3 technical support
Post Reply
radulepy
Post by radulepy » Sat Dec 15, 2018 8:12 pm
Hello guys,
I have a problem with my Det 3 in my 98' NB 1.6 Miata.
I connected the crank(ignition) senzor, the maf(analog 1), and the MAP(included) right after the throttle body, to the det3 and their output to the ecu.
The RPM output it higher than my cars tach (+800 ~ RPM).
And if i accelerate the line (in the table) only goes up and down and not right or left.
I don't know if the fuel map even works... ?
Any ideas ? Thank you!
The scheme i used and the video:
https://drive.google.com/open?id=1NUy0V ... 3Ayc9KsC7A
https://drive.google.com/open?id=1uK0Sd ... foGDZweSfN
mccolome
Re: MIATA WRONG RPM READ DET3 +VIDEO
Post by mccolome » Fri Jan 04, 2019 9:15 pm
Wouldn't you need the TPS wired in too?
Post Reply
stół kuchenny okrągły
Who is online
