Honda OBD2A Wiring help
DET3 technical support
Post Reply
Richardc9052
Post by Richardc9052 » Mon Jan 25, 2016 1:41 am
Hi.
My friend recently bought a DET3 for his D15 Sohc OBD2A honda civic EK3.
We are having trouble with the ignition wiring. We have manage to get an rpm signal but unfortunately cannot adjust timing or activate launch control (which we use as test).
Please can somebody advise the correct wiring for this car.
Thank you.
Richard
ihiryu
Re: Honda OBD2A Wiring help
Post by ihiryu » Tue Jan 26, 2016 9:02 pm
Did you cut and splice the crank/cam sensor?
Richardc9052
Post by Richardc9052 » Wed Jan 27, 2016 1:35 pm
Yes. This isn't my first install. But my first on honda.. It's really qannoying mee... Thank you for replying :)
ihiryu
Post by ihiryu » Thu Jan 28, 2016 8:09 pm
You have the launch control setup to where it's always on? Just to check it?
Richardc9052
Post by Richardc9052 » Sat Jan 30, 2016 1:26 pm
Yep :) said that in the first post
ihiryu
Post by ihiryu » Sun Jan 31, 2016 9:08 pm
Only thing I can think of is that you may need to use a pull up.
Harrym999
Post by Harrym999 » Mon Apr 30, 2018 5:51 pm
Hi Richard,
I believe your issue is that the turbo on the car is too small.
Post Reply
stół kuchenny okrągły
Who is online
