Bugs and Feature reqests
pric
Re: Bugs and Feature reqests
Post by pric » Mon Sep 25, 2017 10:22 pm
Any news on the knock control?
I'd like to have a manifold pressure or tps based activation/deactivation.
(As mentioned nearly a year ago , i get huge spikes when letting off the throttle.
http://forum.ecumaster.com/viewtopic.ph ... 637#p18637)
I want to be finally able to use the knock control, not just look in the logs afterwards...
Mercedes C280 M104 Turbo
selfdestroyer
Post by selfdestroyer » Fri Sep 29, 2017 5:46 pm
Feature request
It would be good to have the separate ignition map (1x6) for idle. My engine very well works by 4 degrees of BTDC but in other modes use of such corner not reasonably
Thank You
nickbmw
Post by nickbmw » Fri Sep 29, 2017 7:40 pm
Are we ever going to have simple and basic things like a 2d table for fuel cut rpm vs coolant?
Idle afterstart increase vs coolant temp?
Strategy to keep the idle pid inactive during deceleration?
Also requested the same thing a long time ago.
Feature request
Thank You
I use idle ignition vs coolant table to get the idle ignition angle where i want it without messing with the ignition map.
selfdestroyer
Post by selfdestroyer » Sat Sep 30, 2017 10:41 am
Dear nickbmw my message was addressed to software developers. This normal solution receiving a flag "idle" to use the separate ignition map. Your decision is convenient for you. For twisting of screws, it is necessary to use the screw-driver, but not the hammer ;)
GearTech_Greece
Post by GearTech_Greece » Mon Oct 02, 2017 11:06 pm
A very minor correction: can you please make Boost table set show '0' or 'OFF' when 'disable solenoid input' is active? It currently shows boost table set 1 for both conditions (solenoid disabled AND boost 1 active).
adam88sc
Post by adam88sc » Mon Nov 06, 2017 4:08 am
Is there any chance we could get boost target added to the serial protocol?
Thanks!
Adam
fataznwithcake
Post by fataznwithcake » Sun Nov 12, 2017 4:50 am
How about adding rpm change rate as a logging parameter? That’s what I used to tune when I didnt have access to a dyno before I switched to the emu.
pric
Post by pric » Mon Nov 13, 2017 9:12 pm
There is a inbuilt Dyno function on the EMU client.
military
Post by military » Thu Dec 14, 2017 10:30 pm
Hi it is possible to make sequential shift light?
pric
Post by pric » Sat Dec 23, 2017 3:54 pm
Now that's a nice christmas Gift:
"Change log for version 1.206
• Min and max TPS/MAP values added to the knock action"
Thank You!!
BobX
Post by BobX » Mon Jan 01, 2018 6:04 pm
On my Mini R53, I can't control the check engine lamp manually. Using a param output or the "Invert Output" in the check engine panel do not work. Is it a limitation of the CAN bus ?
fataznwithcake
Post by fataznwithcake » Tue Jan 16, 2018 11:31 pm
The reason I wanted to log RPM change rate was because the dyno feature was separate from the data log graph. With RPM change rate you could tune and have all data on one screen.
WHPZach
Post by WHPZach » Wed Jan 24, 2018 5:25 pm
It's already a logged parameter, TC dRPM
military
Post by military » Tue Feb 06, 2018 9:44 am
Hi it is possible to make:
Shift light by speed from ABS reading? (1st light 60kmh, 2nd 110kmh and etc.) it can be second shift light, different from engine rpm shift light.
ihiryu
Post by ihiryu » Tue Feb 06, 2018 9:38 pm
Feature request.
To allow a stepper output to invert in the nitrous menu!
Marc Knoll
Post by Marc Knoll » Sat Feb 17, 2018 8:54 pm
Feature Request for Android EMU App
Boost Target
Boost ( BAR ) not only kpa and PSI
Jeepster
Post by Jeepster » Thu Mar 15, 2018 2:57 pm
"Fuel usage" may be wrong factor if using Alpine Trigger 66-2-2-2 with cam sync.
running with 36-1 Trigger I got idle fuel usage of 2 l/h
running the Alpine Trigger it shows me an idle fuel usage of 6 l/h
lambda keeps the same with both triggers
...no big problem :lol:
Sam8888
Post by Sam8888 » Wed Mar 21, 2018 8:58 pm
Requests:
- To be able to tune the EMU through bluetooth, in this way a shouldn't use the USB cable (did this on VEMS all the time)
- 3D IAT correction table
- Fuel pump PWMing
+1: collant fan pwm speed control
Android app:
- GPS speedometer
- Automatic connection to the ecu (for automated phone dash)
- Shift light
dulet
Post by dulet » Sat Mar 24, 2018 7:13 pm
Regards to all ! I need your help! I install emu ecu on the ABF vw engine. I have an alternate problem with injection and spark.Rejecting two nozzles and two cylinders have no spark. when I'm doing the test everything is okay every nozzle works and the duble ignition coil fires in pairs (1 exit 1 + 4 and the third exit 2 + 3)! When i too the scoup perfectly notice every tooth and the spaces are the same. I do not know what to do, but I do not know what to do with it. When I turn off the coil, the nozzles run normally
Post by PSI-Motor » Sat Mar 24, 2018 7:25 pm
This is a feature request thread... Do a new thread and post your map and log otherwise we can't help you.
Post Reply
stół kuchenny okrągły
Who is online
Users browsing this forum: No registered users and 3 guests
