ANDROID DASH - VERSION 2.1.0 - Available in Google Play
BigMac
Re: ANDROID DASH - VERSION 2.1.0 - Available in Google Play
Post by BigMac » Wed Mar 23, 2016 6:08 pm
It's just a different type of sensor/controller and I don't know why it has different reading.
Best lean power is 13.1 on the Bosch LSU 4.2 using Innovate or EMU -they read the same as you can see
If I was doing a quick tune using the dyno wideband I'd just tune to 12.8 as a target
Post by PSI-Motor » Wed Mar 23, 2016 7:30 pm
I have compared EMU vs Bosch Motorsport lambda and they are EXACTLY the same :)
BigMac
Post by BigMac » Wed Mar 23, 2016 7:39 pm
It's not a Bosch Motorsport and its a few years old :D
ocerrr
Post by ocerrr » Wed Mar 30, 2016 11:01 am
Would Android Dash working well as a RPM gauge? I mean it can connect and running automatically and how long is the delay time.
I suffer from RPM gauge delay a lot, on stock gauge and low end ebay gauge.
If this android dash working well like a LCD data logger It will save a lot money!
clamp
Post by clamp » Wed Mar 30, 2016 1:28 pm
i found new bug .,. when i make rec. with android dash.
my MAP make some bug and show 254...
this is my log with android dash.
pepifebles
Post by pepifebles » Wed Mar 30, 2016 5:20 pm
I have Issues with Any channels. Afr its ok but lambda channel always show 0. 1.1 emu version.
The fun starts now
nickbmw
Post by nickbmw » Sat Jun 18, 2016 9:31 pm
I have issues connecting to the bluetooth module. I have to try 5-6 times, sometimes it will not connect at all, from both my phone and my tablet. It is very annoying.
Post by RHD » Sun Jul 03, 2016 11:55 am
is there a bug with the fuel pressure delta gauge???
or am i doing something wrong?
it seems to be in the wrong units and stuck on 100Kpa
dan_t
Post by dan_t » Sat Jul 23, 2016 2:20 am
derOJ wrote:I habe problems with logging.
I made 4 Loge with the app but Windows client cannot read them.
Two of the logs Werke at least 2 Minuten long.
But client only shows 10 seconds or so....
I also am unable to to get propper logging via the APP. I have done several logs of various lengths but when opened in EMU Client I only get 5 or so seconds of data logged.
Copy of EMULog_20160723_070032.log
added .log file extension for upload
(50.72 KiB) Downloaded 59 times
bulkans
Post by bulkans » Fri Sep 09, 2016 1:09 pm
Display mode with 4x2 or 4x3 grid would be great. Maybe something similar as it is on VemsDisplay.
nickbmw
Post by nickbmw » Mon Sep 19, 2016 11:39 am
Once more, it is very annoying to have to hard-reset the application every time to use it. When are you going to fix this?
flubyux2
Post by flubyux2 » Sun Oct 23, 2016 7:22 pm
is there ever going to be an iphone app? or is there an obd2 scanner app that will work with reading data from the emu?
jpbello07
Post by jpbello07 » Fri Dec 23, 2016 8:48 pm
Would be great to include an internal GPS speedometer for people who can't run speedos. (My setup with CD009 in an S14 - 350z speed sensor is located in their differentials) Other than that, great app!
Astroboy
Post by Astroboy » Thu Apr 06, 2017 11:42 am
I'm having issues with logging and also log content. Sometimes the logs don't record at all and when they do half of the channels are missing please help!
I also had a random Check Engine light illuminate for high exhaust gas temperature (65187C) but I have no probe fitted
Astroboy
Post by Astroboy » Fri Apr 07, 2017 6:55 pm
Astroboy wrote:I'm having issues with logging and also log content. Sometimes the logs don't record at all and when they do half of the channels are missing please help!
Anyone else having the same problem?
Astroboy
Post by Astroboy » Sat Apr 08, 2017 6:00 pm
I could really do with some assistance on this. I now can't log at all. The app shows as recording but there are no logs. I am also now getting random 'check engine' lights flashing up
ESRA Car performance
Post by ESRA Car performance » Fri Dec 29, 2017 4:09 pm
can this connect thru usb already?
Post Reply
stół kuchenny okrągły
Who is online
