Pops and bangs
Post Reply
pepifebles
Pops and bangs
Post by pepifebles » Sun May 27, 2018 1:56 pm
Hi guys, I’m trying tune for get pops and bangs but dont get anything :roll:
Retard ignition and enrich mixture in vacuum cells not work. Any advise??
The fun starts now
maKe
Re: Pops and bangs
Post by maKe » Tue May 29, 2018 7:34 pm
You mean between shifts and when deaccelerating? I don't get bangs there because it cuts fuel immediately when lifting throttle. Rev limiter is ignition + fuel cut strategy and it's like AK47 gunshots when spinning 2nd and 3rd to 8200rpm's. :mrgreen:
pepifebles
Re: Pops and bangs
Post by pepifebles » Tue May 29, 2018 8:47 pm
Yes, between shifts and decel. How can get it?
The fun starts now
pepifebles
Re: Pops and bangs
Post by pepifebles » Tue May 29, 2018 9:07 pm
Its possible that dont fuel cut inmediately?
The fun starts now
pepifebles
Re: Pops and bangs
Post by pepifebles » Wed May 30, 2018 10:33 pm
Something like this will be happy
https://youtu.be/AvrY1dUm7r0
The fun starts now
maKe
Re: Pops and bangs
Post by maKe » Sun Jun 03, 2018 8:39 am
Try to look into fueling -> fuel cut tab and see what happens when you change overrun fuel cut decay rate and resume enrichments. I really have no other clue other than just bump up fueling in the vacuum cells also. Maybe injection angle might have a desired effect if you try to inject "too late" in the low vacuum cells when lifting throttle.
rolfts
Re: Pops and bangs
Post by rolfts » Fri Jun 29, 2018 8:18 pm
the folowing wil only make flames and minor bangs:
- go to your fuel cut tab
- make sure it wont cut fuel under deaccel
- bump up either condition under which it wont cut the fuel (fuel cut underpressure/tps limit/rpm limit)
- check the box with (dissable spark when overrun....)
- make make the low map cell's in your VEtable lower than lambda 1 (you need a lean mixture for it to self
combust) experiment with the exact lambda value you need for your pops.
you are now obligated to post a movie of your result here :mrgreen:
pepifebles
Re: Pops and bangs
Post by pepifebles » Sat Jul 21, 2018 11:52 pm
Hi, sorry for delay. I try this setup. Thanks.
If I get it, upload video 👍
The fun starts now
Schlander
Re: Pops and bangs
Post by Schlander » Wed Aug 01, 2018 2:32 pm
Lower than 1?? Then it would be rich?
MichaelShock
Pops and bangs
Post by MichaelShock » Mon Sep 03, 2018 3:02 pm
For those of you out there running the Eurocompulsion Pops and Bangs update is it worth it? I am tempted to get it however I am concerned it might be a little too obnoxious for daily driving? Is there a way to have it only on in sport mode perhaps? How does it effect fuel economy? Let me know your thoughts Thanks
pepifebles
Re: Pops and bangs
Post by pepifebles » Mon Sep 17, 2018 8:04 pm
It depends on how aggressive you set it. I personally like it and it only works under certain conditions. Driving normal should not do it. You can activate it with switch
The fun starts now
Post Reply
stół kuchenny okrągły
Who is online
