AFR Spikes (2JZ-GTE)
Posted: Fri Jan 12, 2018 10:15 pm
by SSC_Master
Hi mates,
Actually I’m trying to find some good settings that the AFR values follows the AFR target table.
I’m 70% happy with the result. When I push the pedal the values reflects what’s written in the table.
My problem are these spikes at the begin and at the end of an acceleration sequence. (see pictures)
Have you any ideas which parameter I have to adapt in the EGO Feedback section to erase these spikes ?
Regards
The attachment AFR_1.jpg is no longer available
The attachment AFR_3.jpg is no longer available
Re: AFR Spikes (2JZ-GTE)
Posted: Sat Jan 13, 2018 2:13 am
by daniel@post-haste.ca
That's going to be in the Enrichment settings - check the log for your Enrichment's
Posted: Sat Jan 13, 2018 2:40 am
by Marc Knoll
First Spike >>> Throttle Enrichment
Second Spike >>> Fuel Cut settings
Posted: Sat Jan 13, 2018 1:47 pm
by SSC_Master
Thank you very much for your answer.
I very appreciate it. Because it is new for me it’s
not so easy to see the influence of the different aspects.
Is it right to adapt the parameter to eliminate the first spike in the section (picture first spike) and for the second spike (picture second spike) ?
Yours sincerely
