EMU Software 1.1 BETA 1 already available!
Get information about latest versions of software
Post Reply
Post by Jadzwin » Fri Jan 16, 2015 11:33 pm
Hi there!
We are about to launch EMU 1.1 software. You can test the beta version now.
There is a Help in English to all EMU options, however it is only partially proof read.
We focused on fixed some crashes in Windows Client. We also add Contributors list to mention all the people that were involved with software developement.
If someone was missed please contact us.
We are waiting for your comments.
http://ecumaster.com/testVersions.html
Ecumaster Team
Re: EMU Software 1.1 BETA 1 already available!
Post by PSI-Motor » Sat Jan 17, 2015 5:46 pm
If you try to press 8 och 9 in a mapp it toggle between pages. Makes it hard to write any numbers in maps with those numbers ;)
Seems like you have to have English keyboard settings? Thats a bit of a problem in Sweden :)
Edit. doesnt work with english either.
You can only use the numberpad to your right on a stationary keyboard wich doesnt exist on the laptop.
Post by PSI-Motor » Sat Jan 17, 2015 7:32 pm
Lets say your at Desktop 1 and you double click on the VE table for example and it becomes a large screen.
Like this.
Then all the other desktops follow.
Like this.
Then if you want to minimize them to normal you cant and you have to drag the mouse in the corners to make it smaller on every desktop och click the X and start over.
Post by PSI-Motor » Sat Jan 17, 2015 8:05 pm
And when you do the things above all your desktops is copied and gathered on all your desktops. You can see this if you drag them to normal size.
Like this.
When this has happend you can`t get rid of it using the X if your not in the original desktop were you set it upp from the start.
Post by PSI-Motor » Sat Jan 17, 2015 8:52 pm
The gauges.
IAT, CLT and AFR Target doesn´t work to klick on. But if you go to Dashboard desktop they are present.
And if you click on lambda gauge it becomes enormous.
And fo example the map gauge is smaller than the others.
Post by Jadzwin » Sun Jan 18, 2015 1:29 am
New version BETA2 is available. OPEN GL corrections mainly.
PSI:
With the maximizing windows issue you need to wait a little...
Post by PSI-Motor » Sun Jan 18, 2015 1:39 am
Jadzwin wrote:New version BETA2 is available. OPEN GL corrections mainly.
PSI:
I can wait :)
The main problem is key 8 and 9 and IAT, CLT, Lambda and afr target :)
Post by Jadzwin » Sun Jan 18, 2015 2:33 am
Can you explain more ? Did I miss something ?
clem
Post by clem » Sun Jan 18, 2015 6:03 pm
I just wanted to try 1.1 Beta 2 but have problem with upgrading firmware.
When connecting emu to the laptop, the maps begin to be loaded to the computer like normal. As soon as this task is finished, windows says "dieses programm funktioniert nicht mehr" in english "This program does not work anymore"... So I cant upgrade the firmware from 1.071 to 1.1
Cheerio Clem :)
Post by Jadzwin » Sun Jan 18, 2015 7:39 pm
Can you send us your EMU configuration and desktops.xml file from your device subdirectory ?
tech(at)ecumaster.com
Racekid21
Post by Racekid21 » Mon Jan 19, 2015 12:05 am
Works great! Thanks a lot :))))
Post Reply
stół kuchenny okrągły
Who is online
