There is new software version available 1.070
Actually anti lag is working but we DID NOT TEST IT IN REAL APPLICATION.
During drive activate strategy by switch, the target RPM will be stored.
It will not work under 1000 RPM.
Then the EMU will try to keep boost target and target RPM.
If your boost will be under the target lower boost kP otherwise increase boost kP.
Control range is the RPM range below the target RPM when the boost and RPM limit is performed.
Any comments will be very valuable.
Next improvement is Frequency input divider for VSS input. It is useful for high frequency signals (eg. Honda vss).
There is also new option for FlexFuel sensor. Now it can be also connected to the VSS input.
For windows client there are two improements:
1) The status bar shows now state of different strategies:
Abbreviation:
LC - Launch control
FC - Fuel cut
SC - Spark cut (for any strategy that use spark cut percent)
ALS - Anti lag
KS - Knocking
RAL - Rolling antilag
POx - State of parametric output
2) On About box there is device uniqe serial number displayed
The software can be downloaded here:
http://www.ecumaster.com/testVersions.html
